Página 1 de 241 123611152550100 ... ÚltimoÚltimo
Mostrando resultados del 1 al 12 de 2884
Tema: SIGMA 150-600mm F5-6.3 DG OS HSM C | Contemporary
    Predeterminado SIGMA 150-600mm F5-6.3 DG OS HSM C | Contemporary
    Sigma ha anunciado hoy el nuevo objetivo SIGMA 150-600mm F5-6.3 DG OS HSM que quedará incluido dentro de su gama C, Contemporary.
    Sigma ya dispone de un objetivo con el mismo rango focal pero perteneciente a su gama Sport, por lo que con este nuevo objetivo trata de abarcar otro tipo de fotógrafo primando más el que el objetivo sea ligero y compacto frente a que sea rápido y preparado para los deportes y acción del de la serie Sport.
    Nota de prensa
    A lightweight hyper-telephoto zoom lens featuring high usability and outstanding optical performance. The latest fine lens in our Contemporary line.
    1. High image quality and a compact construction based on the product concept of our Contemporary line.
    2. Enhanced functionality for better portability and usability.
    3. Customization and flexible adjustment for convenience or a specific purpose is possible.
    4. Compatible with the newly developed tele converters.
    5. New product lines from SGV concepts that are setting new benchmarks for image quality.
    The same focal ranges for different purposes. The first hyper-telephoto zoom lens from our Contemporary line for better usability.
    On the one hand, the product concept of the SIGMA 150-600mm F5-6.3 DG OS HSM | Sports is to achieve the best optical and action-capture performance to meet the requirements of professional photographers. On the other hand, that of the SIGMA 150-600mm F5-6.3 DG OS HSM | Contemporary is to achieve a lightweight and compact construction for higher usability with similar specifications. It has put a special emphasis on its optical performance by incorporation of 1 FLD and 3 SLD glass elements, optimization of lens power distribution and minimized chromatic aberration of magnification. An issue for hyper-telephoto lenses in particular at the telephoto end, optical aberrations have been minimized throughout the zoom range. Dust- and splash-proof to facilitate photography in the field and featuring a detachable tripod socket for more convenient handheld photography, this lens is a lightweight high-performance model offering outstanding usability.
    • By incorporating excellent optical glass elements, it minimizes chromatic aberration and achieves class leading image quality.
      This lens incorporates 1 FLD (“F” Low Dispersion) glass element, which has performance equal to fluorite, and 3 SLD (Special Low Dispersion) glass elements, and compensates for chromatic aberration at the utmost. Chromatic aberration in particular, which could be visible especially towards the telephoto-end even when stopped down, is corrected by the optimized design of glass elements including the FLD lens.
    • Lightweight and compact construction for higher usability
      Compared to the SIGMA 150-600mm F5-6.3 DG OS HSM | Sports, it is more compact and lightweight, enabling easy handling and making it possible to do handheld photography for a longer period of time. The tripod socket is detachable so that the lens can be carried by itself. Without the tripod socket, it also fits well into limited space for storage.
      Moreover, the tripod socket is made of magnesium which is light and strong at the same time. The tripod socket may be detached and replaced with a rubber protective cover to further reduce weight and make handheld photography an even more lightweight and convenient experience. This lens is the optimal choice for photographers who desire hyper-telephoto functionality while staying light on their feet.
    • Intelligent OS featuring updated algorithm
    The OS (Optical Stabilizer) function features an acceleration sensor to ensure even higher precision. Two OS modes are available: Mode 1 for general photography and Mode 2 for motor sports and other applications requiring panning. In Mode 2, the acceleration sensor teams up with the Intelligent OS and its updated stabilization algorithm to deliver effective stabilization while you move the camera horizontally, vertically, or diagonally—regardless of the position of the lens. This feature helps ensure effective panning and outstanding capture of moving subjects.
    Note: This lens is incompatible with film SLR cameras with the exception of the Nikon F6 and Canon EOS-1V.
    • Zoom lock switch can be set at any focal length
    The new zoom lock switch enables the zoom ring to be locked at any focal length. It can be fixed at the photographer’s desirable focal length, which allows stable shooting whether the lens is positioned upward or downward. It also helps during long exposure photography.
    • Water and oil-repellent coating ensures a pleasant photography experience
    The forefront lenses incorporate a water and oil-repellent coating that allows water to be wiped away easily and prevents oil and fat from sticking to the surface, even in challenging shooting conditions. At the sametime, the maintenance of the lens surface becomes easier.
    • Dust-proof and splash-proof mount
    As with the SIGMA 150-600mm F5-6.3 DG OS HSM from the Sports line, the lens mount incorporates rubber sealing to protect the mount part from dust and water drops.
    • Quieter and Faster “Optimized AF”
    The HSM (Hyper Sonic Motor) ensures high speed and quiet AF. With the further enhanced AF algorithm compared to previous models, continuous AF (AF-C) improves the focusing efficiency by approximately 5%.
    ● Manual override incorporated to make two full-time manual modes switchable.
    In addition to AF/MF, MO (Manual Override) is incorporated as one of the options of the focus mode switch. By setting it to the MO position, it switches to manual focus by rotating the focus ring even during continuous AF. With AF position, standard full-time manual focus is available. Using the optional
    SIGMA USB DOCK, it is possible to adjust the MO position’s sensitivity to switch to manual focus.
    ● SIGMA USB DOCK - Customizable to your needs
    Customization including firmware updates, focus adjustment, setting of full time manual operations as well as adjustment of the timing to switch to MF when rotating the focus ring is available with the optional SIGMA USB DOCK, by connecting it with the dedicated software “SIGMA Optimization Pro” on a
    computer. With this lens, custom mode that can be set depending on the photography situation is available by switching it on the lens. Through custom mode, it is possible to set AF speed, focus limiter where desired focus range can be adjusted, and OS where one of the patterns for optical stabilizer can be selected from “Dynamic View Mode”, “Standard” and “Moderate View Mode”.
    4. Compatible with the newly developed tele converters (sold separately).
    ● AF is effective up to F8
    Tele Converters that are newly designed to match the new lens line-ups (optional) can be attached. The addition of SIGMA’s TELE CONVERTER TC-1401 or TELE CONVERTER TC-2001 produces a MF 210-840mm F7-9 hyper-telephoto zoom lens or a MF 300-1200mm F10-12.6 hyper-telephoto zoom lens respectively. In addition, when SIGMA TELE CONVERTER TC-1401 is attached to cameras that are compatible with AF at F8, it is possible to shoot with AF.
    * When shooting subjects with low contrast or luminosity value, focus may not be spot on the subject.
    [Contemporary]
    Leveraging the latest technology to combine outstanding optical performance with compact design, this line is perfect for a wide range of photographic scenes.
    SIGMA is organizing all its interchangeable lenses into three product lines; Contemporary, Art and Sports. Among the three, the Contemporary line is a high performance line which incorporates the very latest technology making it possible to accommodate both high optical performance and compactness for use in various photography situations. SIGMA has solved the difficult problem of keeping the size and weight down without compromising optical performance and function with the latest technology.
    [SIGMA GLOBAL VISION]
    “SIGMA GLOBAL VISION” - SIGMA is working on its full renewal of the products, and the new lens lines share all the following elements.
    ● Evaluation with SIGMA’s own MTF measuring system “A1”
    We used to measure lens performance with an MTF measuring system using conventional sensors. However, we’ve now developed our own proprietary MTF (modulation transfer function) measuring system (A1) using 46-megapixel Foveon direct image sensors. Even previously undetectable
    high-frequency details are now within the scope of our quality control inspections. All SIGMA 150-600mm F5-6.3 DG OS HSM | Contemporary lenses will all be checked using this “A1” before they are shipped.
    ● “Made in Japan” with the best craftsmanship
    All SIGMA's manufacturing – right down to the molds and parts – is carried out under an integrated production system, entirely in Japan. We are now one of the very few manufacturers whose products are solely "made in Japan". We like to think our products are somehow imbued with the essence of our homeland, blessed as it is with clean air and water, and focused hard-working people. We pride ourselves on the authentic quality of SIGMA products, born of a marriage between highly attuned expertise and intelligent, advanced technology. Our sophisticated products have satisfied professionals and lovers of photography all over the world, because our manufacturing is based on genuine craftsmanship, underpinned by the passion and pride of our experts.
    ● Applicable for the Mount Conversion Service that enables lenses to be long term assets
    Over the years, SIGMA has manufactured an extremely wide variety of interchangeable lenses. Leveraging our unique know-how and resources, we present our new mount conversion service, which is available for the interchangeable lenses from our new product lines. SIGMA will convert the
    current lens mount internal components, allowing you to continue using your favorite SIGMA lens with a different camera body. Thanks to this service, you can use a favorite lens for many years to come, unrestricted by your original choice of camera system.
    Note: SIGMA’s mount conversion service differs from ordinary repairs and product support and is not offered at your local
    SIGMA dealer or camera store. In order to apply for the service, please contact your nearest authorized subsidiary/ distributer of SIGMA.
    [Other Features]
    ● Brass made bayonet mount
    This lens incorporates a brass bayonet mount which has both high accuracy and durability. A special treatment to reinforce its strength is applied to the surface giving it greater strength and making it highly resistant to long-term use.
    ● Designed to minimize flare and ghosting
    Flare and ghosting were thoroughly measured and monitored from the lens development stage to establish an optical design which is resistant to strong incidental light such as backlight. The Super Multi-Layer Coating reduces flare and ghosting and provides sharp and high contrast images even in backlit conditions.
    ● Incorporating Rounded Diaphragm
    The 9 blade-rounded diaphragm creates an attractive blur to the out-of-focus areas of the image.
    abr 2007
    Se supone que éste es el rival directo del tamron, no el S.
    Haber cuando nos enseñan imágenes, comparativas y...........precio.
    Aquí en Sigma Rumors aparece la comparativa con su hermano mayor, sorprendiéndole a 150mm. Curioso.
    http://sigma-rumors.com/2015/02/sigm...ports-version/
    DIFERENCIAS ENTRE SIGMA 150-600 CONTEMPORARY y SIGMA 150-600 SPORT
    Ante las preguntas de algunos compañeros sobre las dudas entre ambas lentes, y en que se diferencian ambos, y porque, uno vale tanto y el otro casi el doble, si los dos parecen iguales por el nombre cuando solo cambia una palabra Contemporary o Sport, escribo aquí un breve resumen para poder ayudar con un primer vistazo al que este interesado en alguno de ellos.
    ---El Sigma 150-600 Contemporary es la versión construida en polímero de los dos siendo por eso, mas contenido en peso y en tamaño, si lo que queremos es salir de paseo con una lente de 150-600mm. de focal. La competencia directa de este seria el Tamron SP 150-600 en su primera versión como en la ultima denominada G2, y que en calidad óptica son muy similares, aunque unos vean mejor unos que otro, las diferencias que existen entre ellos habría que mirarlas con lupa.
    La ventaja que podría inclinar la balanza hacia el lado de los Sigma o la nueva versión del Tamron 150-600 G2, es un accesorio llamado Dock en el caso Sigma y Tap-in en el de Tamron con los cuales podemos personalizar las lentes, de forma que ningún fabricante mas ha hecho hasta ahora teniendo así unas lentes mas completa en aspecto específicos para la fotografía de la naturaleza u otros campos en los que se quiera utilizar una lente con ese potencial óptico.
    ---El Sigma 150-600 Sport es la versión tanque de guerra de los anteriores, por peso, por volumen y por construcción, aunque la nueva versión del Tamron 150-600 G2 esta también fabricada en metal sin casi aumento de peso y con el mismo sellado que la versión del Sport de Sigma. Pero esta ultima no es una lente para un, no iniciado en el mundo de los grandes teleobjetivos pero si se atreve que se prepare porque es una lente para hombres de pelo en pecho........y no es coña. En el, todo es a lo grande, guardarlo, llevarlo o utilizarlo a mano, esto ultimo, no es lo suyo pero tampoco es imposible, si se hace con la ayuda de un monopie.
    Su calidad óptica en este caso, si es un poquito mejor que los otros pero siempre en el extremo mas alejado de la focal donde los otros empiezan a perder un poco o desfallecer a su máxima apertura, este no lo hace. Es, el claro ejemplo o la prueba de porque este tiene cuatro lentes mas que el Contemporary o los dos Tamron. El precio por lo tanto, en euros a pagar es por ello de casi el doble, o una tercera parte mas que la nueva versión G2 del Tamron, y que se refleja en el objetivo por su construcción metálica absoluta, su sellado para la intemperie y provocando, por ser un 20% mas grande en volumen que sea también un 50% mas pesado, frente a su hermano pequeño o sus alternativas de Tamron.
    A este también hay que sumarle las capacidades especiales que ya trae el Contemporary y la nueva versión del Tamron 150-600 G2, a las cuales se accede gracias al Dock del Sigma o el Tap-in de Tamron. Como he dicho antes, las prestaciones ofrecidas gracias a estos accesorios los ponen en una categoría, digamos, que superior, justo detrás de las lentes mas profesionales, que han existido siempre, y que hasta ahora estaba vacia o huérfana, y que por lo tanto, son únicos en su especie.
    Espero que le haya ayudado a alguien este pequeño resumen y decir que si se necesitan mas datos, lean este foro para averiguar alguna otra cosa como los de fotos con las mismas.
    Manual y Guía
    Para los que no saben para que sirve y como se puede utilizar el Dock, abajo he puesto un manual, un poco cutre, sobre el mismo para explicar su funcionamiento y como poder sacarle el rendimiento que nos ofrece. Además, también hay una especie de guía rápida para orientar a los neófitos en la materia mostrándoles unos pasos que pueden seguir y así, no perder tiempo, descubriéndolos tarde y mal.
    Manual del Sport, escaneado, no diferirá mucho del que trae el Contemporary pero si alguien lo puede escanear que me lo pase y me encargo de que se coloque aquí y asi tenemos toda la información en un punto para lo que sea.
    https://www.dropbox.com/s/afqhz1fxkv...iones.pdf?dl=0
    Manual del Dock, oficial de Sigma, en castellano porque no encuentro el enlace original así, que uso uno personal.
    https://www.dropbox.com/s/bjl1jrrr1w...ol%29.pdf?dl=0
    Manual y posibles usos del Sigma DOCK. [Corregido y Actualizado]
    https://www.dropbox.com/s/vzkl8xt93x...anual.pdf?dl=0
    Fotografía de Naturaleza (Base y Equipamiento). Definitivo.
    https://www.dropbox.com/s/sal87i2tpb...to%29.pdf?dl=0
    Si no funciona pulsando encima probar a copiar el enlace y pegarlo en una pagina nueva. En el caso extremo de que aun así no se puede bajar enviarme un privado y lo paso personalmente.
    Hilos de las lentes Sigma Contemporary, Sport, y Sigma Dock:
    Sigma Dock y Optimization Pro.
    http://www.canonistas.com/foros/opti...-manuales.html
    Contemporary.
    http://www.canonistas.com/foros/tele...temporary.html
    Sport.
    http://www.canonistas.com/foros/tele...arecer-26.html
    Tus fotos con el Sport.
    http://www.canonistas.com/foros/tele...sm-sports.html
    Ayuda para la calibración de objetivos
    https://www.canonistas.com/foros/sho...d.php?t=551814
    Última edición por Spyder; 22/11/18 a las 11:58:44
    Bueno, al final el precio, en la tienda de New York, B&H, es de 1.089 dólares para ser servido a partir del 20 del mes Marzo en el presente año. Dando por hecho que con bolsa incluida, personalmente para mi todo un detalle.
    Última edición por Spyder; 11/02/15 a las 21:56:21
    abr 2007
    Pinta bien.
    Repetido, perdón.
    may 2013
    En tierra de antiguos vetones
    Un precio muy asequible para ser el de lanzamiento. Gracias Spyder.
    A ver
    si pronto, cuando salga, haya personas que lo tengan en su haber y podamos tener comparativas fiables.
    La seriedad en una persona se demuestra con sus hechos, no con sus propias palabras.
    Gracias por la información. Me lo esperaba algo más caro. Ahora a esperar comparativas con el Tamron.
    Última edición por Shot; 23/02/15 a las 06:04:09
    Huelva (Onuba Aestuaria)
    Cita Iniciado por Shot Ver Mensaje
    en digital camara lens se puede leer una revisión con una galería de muestras
    A favor :
    - Nitidez excelente entre los 150 y 200 mm., notable hasta los 400 mm. y correcta en los 600 mm.
    Enfoque muy rápido, estable, preciso y muy configurable en todos los apartados.- Construcción, ajustes, acabados y operatividad excelentes.
    - Estabilizador (también configurable) excelente.
    Mejorable:
    Un poco de corrección de ACs laterales.
    - A nivel de ergonomía, el soporte o peana del collarín podría llevar un relieve interno para los cuatro dedos. Cuando se usa como empuñadura con el conjunto hacia abajo, a modo de maleta, da más seguridad.
    - Una tapa frontal de plástico convencional, porque después de todo el equipamiento que lleva de serie la encuentro a faltar.
    http://www.digitalcamaralens.com/Htm...Evaluacion.htm
    es tentador
    Creo que la prueba es del Sport.
